5.3.3. Pipes and Intermediate Heat Exchangers¶
In considering the flow through a pipe or through an intermediate heat exchanger, several factors are taken into consideration. The contribution of the element to \(a_{\text{o}}\) in Eq. 5.2-9 is taken as
where
\(L\) = the length of the element
\(A\) = the flow area of the element
The pressure drop contribution of the element to \(a_1\) in Eq. 5.2-11 is composed of a number of terms. One of these terms is the frictional pressure drop, which is written as
where
\(\Delta p_{\text{fr}}\) = the frictional pressure drop
\(f\) = the Moody friction factor
\(D_{\text{h}}\) = the hydraulic diameter of the element
\(\rho\) = the density of the liquid
\(v\) = the liquid velocity
\(w\) = the liquid mass flow rate
The Moody friction factor \(f\) for turbulent flow in pipes [5-2] is taken as
where
\(C_1 = 0.0055\)
\(C_2 = 20,000\)
\(C_3 = 1.0 \times 10^{6}\)
\(C_4 = 1/3\)
\(\varepsilon\) = the user-supplied roughness of the element
\(\text{Re}\) = the Reynolds number
For laminar flow, the friction factor \(f\) is taken as
The Reynolds number in either case is
where \(\mu\) is the viscosity of the fluid.
A second term is the pressure drop caused by bends in the flow path, and these are modeled as an additional frictional drop term, written as
where
\(L_{\text{B}}/D_{\text{B}}\) = a user-supplied input number for an effective length-to-diameter ratio per bend
\(N_{\text{B}}\) =the number of bends in the element
A third term is the pressure drop to account for baffles or restrictive orifices within the element which cause greater pressure drops than would be accounted for by friction or bends above. This term is taken as
where \(G_2'\) is the minor loss coefficient, defined as
based on the user-provided nominal loss coefficient, \(G_2\) (G2PRDR).
A forth term is the minor pressure loss that occurs at the outlet of an element. This term is defined as
where \(K_{out}\left(Re_{out}\right)\) is the anisotropic Re-dependent loss coefficient
at the outlet of the element, \(Re_{out}\) is the Re number at the outlet of the elment
and \(A_{out}\) is the area at the outlet of the element.
Anisotropic Re-dependent loss coefficients are defined using
EllLossCoefTableID and additional information can be found in Section 5.3.3.1.
A fifth item is the second term in Eq. 5.2-1, which is proportional to the square of the mass flow rate, and is due to the difference in the fluid densities at the inlet and outlet ends of the element. It has the form
where
\(\rho_{\text{O}}\) = the fluid density at the element outlet
\(\rho_{\text{I}}\) = the fluid density at the element inlet
A final term is the gravity-head term for the element, taken as
where
\(z_{\text{out}}\) = the height of the element outlet
\(z_{\text{in}}\) = the height of the element inlet
\(g\) = the acceleration of gravity
\(\overline{\rho}\) = the average of the inlet and outlet fluid densities
Taking the above five terms together, the contribution from the element to \(a_1\) is
The contribution of the element to \(a_2\), which is the derivative of the pressure drops with respect to time, as shown in Eq. 5.2-14, is zero, since the friction factors and the geometry are assumed not to change independently with time. Hence
The contribution of the element to \(a_3\), however, which is the derivative of the pressure drops with respect to the mass flow rate, as shown in Eq. 5.2-16, is obtained by differentiation. For laminar flow, differentiating Eq. (5.3-32) gives
For turbulent flow, differentiating Eq. (5.3-31) gives
Taking the derivative with respect to \(w\) of each term in Eq. (5.3-40), we have for the contribution to \(a_3\)
5.3.3.1. Anisotropic Re-dependent Loss Coefficients¶
Anisotropic Re-dependent loss coefficients can be defined at zone interfaces using Interface Loss Coefficient Tables. Zone interfaces are defined as the inlet of a segment, and the outlet of an element. By default, all zone interfaces are assumed to have a loss coefficient of zero. Only zone interfaces identified in an Interface Loss Coefficient Table will overwrite the default interface loss coefficient. The pressure drop at zone interface \(i\) caused by the loss coefficient is defined as
where
\({variable}_i\) is the variable at interface \(i\), and \(P_{i+}\)/\(P_{i-}\) are the pressure downstream and upstream the interface, respectively. In PRIMAR4, the pressure drop at a zone interface is included in the pressure drop of the element that defines the interface. In the case of a segment inlet interface, the pressure drop is included in the pressure drop of the first element of the segment that defines the interface.
Two functional forms are currently available to capture the dependence of the loss coefficient on the Reynolds number:
Two sets of coefficients may be defined for a given zone interface: one set for forward flow and one set for reverse flow. Additionally, an interface area, \(A_i\), and hydraulic diameter, \(Dh_i\), may be defined for the evaluation of the interface pressure drop and interface Re. If an interface area and interface hydraulic diameter are not provided or are defined as zero, the area and hydraulic diameter of the element upstream or downstream the interface are used. If the upstream element has a smaller or equal area than the downstream zone, the upstream element’s area and hydraulic diameter are used for the interface. If the upstream element has a bigger area than the downstream zone, the downstream element’s area and hydraulic diameter are used for the interface.
Column Label |
Description |
Range |
iEll (Restricted to element outlet table) |
Index of the element outlet where the coefficient will be defined. |
1 \(\leq\) iEll \(\leq\) |
iSGL (Restricted to segment inlet table) |
Index of the segment inlet where the coefficient will be defined. |
Kind |
Kind of functional form for calculating the anisotropic loss coefficient. See Eq. (3.9-24) |
1 or 2 |
C1f, C2f, C3f |
Function coefficients for forward flow |
See Eq. (3.9-25) |
C1b, C2b, C3b |
Function coefficients for backward flow |
See Eq. (3.9-25) |
A (optional) |
Area used to evaluate the Reynolds number and minor pressure loss at the interface. Optional area and hydraulic diameter must be provided as a pair. |
\(A \geq 0\) |
Dh (optional) |
Hydraulic Diameter used to evaluate the Reynolds number at the interface. Optional area and hydraulic diameter must be provided as a pair. |
\(Dh \geq 0\) |
Example Element Outlet Anisotropic Re-dependent Loss coeff. table input:
TABLE <id> ElementLoss
iEll Kind C1f C2f C3f C1b C2b C3b
2 1 0.5 0.0001 1 1.5 100000 -1
3 2 1 10 -0.000001 2 0.0001 0.00001
4 1 1 100000 -1 2.2 20000 -1
END
Example Segment Inlet Anisotropic Re-dependent Loss coeff. table input:
TABLE <id> SegmentTable
iSGL Kind C1f C2f C3f C1b C2b C3b A Dh
1 1 0.5 100000 -1 1.5 2 0 2.2 6.5
4 1 1 100000 -1 2.2 20000 -1 0.002 0.003183099
END
