5.12. Subroutine Descriptions and Flow Charts¶
5.12.1. Subroutine Listing and Description¶
The subroutines used in the PRIMAR-4 module are listed in Table 5.12.1. The driver for the transient subroutines is PRIMAR, and the driver for the steady-state subroutines is SSPRM4.
5.12.2. PRIMAR-4 Module Flow Chart¶
The main subroutines in the PRIMAR-4 module are linked as shown in Figure 5.12.1.
Figure 5.12.1 PRIMAR-4 Module Flow Chart.¶
Routine |
Description |
ANETMP |
Annular element temperatures |
AVGVAL |
Average motor torque over a time step for centrifugal pump |
BYPSTM |
Temperatures of the coolant, reflectors, and duct wall for a bypass channel; called after the flow is known |
CKVLFL |
Check valve flow coefficients |
COREFL |
Estimates core channel flow |
CPCPHT |
Component to component heat transfer |
CUTBAK |
Re-initializes variables when the PRIMAR time step is cut back |
CVTEMP |
Liquid temperatures for a compressible volume, using a one-point perfect mixing model |
DRACSF |
Shell-side flow coefficients for DRACS heat exchanger |
DRACTF |
Tube-side flow coefficients for DRACS heat exchanger |
GRVHED |
Gravity head |
IHXSHF |
Flow coefficients for IHX shell-side |
IHXTBF |
Flow coefficients for IHX tube-side |
INCPVF |
Pressure coefficients for an almost incompressible liquid volume with no cover gas |
INITST |
Initializes arrays for a sub-interval |
INPLNF |
Inlet plenum pressure coefficients |
LIQCV |
Pressure coefficients for a compressible volume with no cover gas |
LIQFIN |
Compressible volume pressure at end of sub-interval, with liquid only and no cover gas |
LQGSFN |
Compressible volume pressure at end of sub-interval, with liquid plus cover gas |
OUTNGF |
Pressure coefficients for a compressible outlet plenum, no cover gas |
OUTPLF |
Pressure coefficients for an outlet plenum with cover gas |
PIPEFL |
Pressure coefficients for pipe flow with friction |
PIPTMP |
Pipe temperatures using Lagrangian mesh |
PMPBLF |
Pressure coefficients for a pump bowl with cover gas |
PMSTRT |
POOLFL |
Pressure coefficients for a pool |
PRESDR |
Pressure drop in a flow element |
PRIMAR |
Main driver for the module |
PRIMR1 |
Simple PRIMAR-1 option, with user-specified driving head vs. time, or flow vs. time |
PRMADJ |
Adjusts inlet and outlet plenum variables to account for the differences between estimated and computed channel flows |
PRMEND |
Puts final sub-interval results into permanent arrays for storage |
PRMPRT |
Prints PRIMAR-4 results |
PRSRZF |
Pressure coefficients for a pressurized (expansion tank) |
PRSTEP |
Finds the next PRIMAR time-step size or decides to cut back the current step size |
PUMPFL |
Pump head and flow coefficients |
PUMPFN |
Pump impeller speed and head calculation at the end of a sub-interval |
RUPSKF |
Pressure coefficients for a pipe rupture sink, guard vessel with cover gas |
RUPSRF |
Pipe rupture source pressure coefficients |
SELECT |
Chooses average and final inlet/outlet temperature into/from a compressible volume, according to segment flow directions |
SSADHX |
Steady-state air dump heat exchanger |
SSBYPS |
Bypass channel steady-state coolant and wall temperatures, given steady-state flow rate and steady-state power |
SSCKVL |
Steady-state check valve pressure coefficents |
SSCPNL |
Steady state null transient driver |
SSIHX |
Steady-state IHX temperatures |
SSIHXC |
Steady-state IHX temperatures, simple model |
SSLQSG |
Steady-state initialization of the elements in a liquid segment |
SSPMLP |
Steady-state initialization of primary loop flows, pressures, and temperatures |
SSPRM4 |
Steady-state initialization of PRIMAR-4 variables – driver for the steady-state routines |
SSPRPL |
Initilization for file 15 binary output |
SSPRSR |
Steady-state pressure and pump head for one segment of an intermediate loop |
SSPUMP |
Steady-state initialization of pump parameters |
SSP4PR |
Steady-state PRIMAR-4 printout |
SSP4TH |
Initialization of node volumes, VOLNDT(ITGP), coolant and wall temperatures, and liquid and wall temperature arrays for pipe-type temperature groups |
SSSCLP |
Steady-state initializaton of the intermediate sodium loops, and also calls the steam generator initialization routines |
SSSTDR |
Steady-state steam generator driver |
SSSTGN |
Steady-state steam generator initialization of simple table look-up option |
SSVALV |
Steady-state valve pressures |
STEPFN |
Finishes liquid flows and temperatures for a sub-interval |
STEPGS |
Gas flow between compressible volumes and storage tanks for a sub-interval |
STEPLQ |
Driver for liquid flow and pressure calculations |
STEPTM |
Driver for liquid temperature calculations |
STGNFL |
Steam generator flow coefficients, sodium side |
STRATV |
Stratified volume calculations |
STRGVH |
Calculates gravity heads in a stratified volume |
SUBSIZ |
Sets the PRIMAR time sub-interval size |
TSDRCS |
DRACS temperatures |
TSIHX |
IHX temperatures, shell and tube sides, and gravity head |
TSIHXC |
IHX temperatures and gravity head, simple model |
TSPRPL |
Writes binary arrays to file 15 for later use |
TSSTGN |
Steam generator temperatures and gravity head, simple model |
VALVAJ |
Steady-state valve pres. drop adjustment. If needed, between compressible volumes connected by several liquid segments |
VALVFL |
Valve pressure coefficients |
